Jul 28, 2021
Dockerize and Deploy a Laravel Application to Production
Koyeb provides developers the fastest way to deploy full stack applications and APIs globally. Want to deploy your Laravel application in minutes? Sign up today and deploy your first service!
Laravel is a popular, simple and flexible PHP application framework. Laravel comes with many build features offering a great developer experience such as thorough dependency injection, an expressive database abstraction layer, queues and scheduled jobs, unit and integration testing, and more.
In this guide, we will explain how to dockerize and deploy a Laravel application to production using Docker to containerize our application and deploy it to the Koyeb Serverless Platform.
By deploying your Laravel application on Koyeb, you benefit from native autoscaling, autohealing, TLS encryption, global load balancing across our edge network, service discovery, and more.
  • Docker installed on your machine
  • A Koyeb account to deploy and run the Laravel web application
  • The Koyeb CLI installed to interact with Koyeb from the command line
  • Have a registry we will use to store our Laravel web app Docker image and deploy it on Koyeb
To successfully deploy a Laravel web application on the Koyeb serverless platform, you need to follow these steps:
  1. Create a new Laravel application
  2. Dockerize the Laravel application
  3. Push the Docker image to a container registry
  4. Deploy the Dockerized Laravel web app on Koyeb
If you already have an existing Laravel application you want to dockerize and deploy on Koyeb, you can jump to the next step.
To get started, we will create a new Laravel project using Composer, a PHP package manager. In your terminal, run the following command:
composer create-project --prefer-dist laravel/laravel laravel-demo
This command will create a new Laravel application in the laravel-demo directory and install all the dependencies required by the app to run properly.
You can launch the application in development mode by running the following command in your terminal from the laravel-demo directory:
php artisan serve
Open a browser window and navigate to the http://localhost:8000 URL. You should see the Laravel welcome page.
With our minimalistic Laravel application ready, we can now create the Dockerfile that we will use to containerize our Laravel application.
We will use the webdevops/php-nginx:7.4-alpine as the base image which provides Nginx with PHP-FPM installed and configured. The image can be customized depending on your needs. You can read the full documentation here. In your application directory, create a new file named Dockerfile and paste the following code:
FROM webdevops/php-nginx:7.4-alpine
# Install Laravel framework system requirements (https://laravel.com/docs/8.x/deployment#optimizing-configuration-loading)
RUN apk add oniguruma-dev postgresql-dev libxml2-dev
RUN docker-php-ext-install \
        bcmath \
        ctype \
        fileinfo \
        json \
        mbstring \
        pdo_mysql \
        pdo_pgsql \
        tokenizer \
        xml
# Copy Composer binary from the Composer official Docker image
COPY --from=composer:latest /usr/bin/composer /usr/bin/composer
ENV WEB_DOCUMENT_ROOT /app/public
ENV APP_ENV production
WORKDIR /app
COPY . .
RUN composer install --no-interaction --optimize-autoloader --no-dev
# Optimizing Configuration loading
RUN php artisan config:cache
# Optimizing Route loading
RUN php artisan route:cache
# Optimizing View loading
RUN php artisan view:cache
RUN chown -R application:application .
As you probably noticed, we don't specify the CMD to tell Docker how to run our container. This is because the base image FROM webdevops/php-nginx:7.4-alpine run the Nginx and PHP-FPM in the foreground and we inherit this command.
If your application requires additional php extensions, you can install them using the docker-php-ext-install command.
In this guide we will push the Docker image to the Docker Hub. You are free to use another different registry as Koyeb allows you to deploy from any container registry.
To build the image run the following command and replace <DOCKER_HUB_USERNAME> with your own.
docker build -t <DOCKER_HUB_USERNAME>/laravel-demo .
Once the build is complete, you can run the image locally to ensure everything is working as expected.
docker run --rm -t -p 9000:80 <DOCKER_HUB_USERNAME>/laravel-demo
Now that we have our Docker image ready, we can push it to the Docker Hub by running:
docker push <DOCKER_HUB_USERNAME>/laravel-demo
Once the image is successfully pushed to the Docker Hub, we can use it to deploy the Laravel application on Koyeb.
With the previous steps completed, we can now deploy our application on production to Koyeb. This section explains how to deploy on the Koyeb serverless platform using the CLI. This operation can also be performed using the control panel.
First, we need to create a Koyeb Secret containing the Docker Hub configuration to deploy private images. In your terminal execute the following command and replace <DOCKER_HUB_USERNAME> and <DOCKER_HUB_TOKEN> with your own.
echo \
  "auths": {
    "index.docker.io/v1/": {
      "username": "<DOCKER_HUB_USERNAME>",
      "password": "<DOCKER_HUB_TOKEN>"
}' | koyeb secrets create docker-hub-credentials --value-from-stdin
We can now deploy the Laravel application by running:
koyeb app init laravel-demo --docker "<DOCKER_HUB_USERNAME>/laravel-demo" --docker-private-registry-secret docker-hub-credentials
This command creates a new Koyeb App and deploy the Laravel application using the Docker image. To retrieve your Koyeb App URL and access your application, run:
$koyeb app get laravel-demo
ID                                  	NAME           	DOMAINS                             	UPDATED AT
d58ebed1-48c0-46b7-a2f1-91f3ffdbcccc	laravel-demo  	laravel-demo-<YOUR_ORG>.koyeb.app	    2021-06-28 12:46:55.411403 +0000 UTC
Open the URL in your browser to access your application running on Koyeb.
This guide shows how easy it is to deploy your Laravel application in production using Docker and Koyeb. Want to deploy your Laravel application with continuous deployment? We have a tutorial for that too. đŸ˜‰
Ready for more PHP resources? Check out our PHP documentation and one-click PHP app to learn how to deploy a PHP application on Koyeb.
Thanks to Koyeb native global load balancing edge network, your content is distributed near your users and your app comes with native TLS encryption.
